Old 9th January 2017, 11:54 PM
Default Speeduino Engine Management?
I have been dabling with Arduino Micro controllers every now and then, until recently I have not had any firm projects but have actually got a number of applications now.
Pond Control
Alarm
Moving Head DMX lamp
Ligthing Desk DMX...
Whilst doing research and brainstorming for these ( Including finding a Buzzer and programming it to play the 5 notes from "Close Encounters")
I came across the speeduino engine management system.
It seems like a reasonable project mounting a sensor/driver shield on a Arduino Mega.
I doubt it would come close to a MeggaSquirt but it's interesting all the same.
A built Shield is $160 but I don't know about shipping to the UK or indeed if it is even worth playing with.
It looks like it actually hails from Australia.
Anyone seen or used it.
Old 12th July 2017, 04:25 PM
geedle geedle is offline
Sorry to resurrect an old thread, but this is what I intend to use on my build too. The guy that is driving the project runs an MX5 so it should be straight forward.
It's not intended to be a replacement for some of the higher end off the shelf ECUs, but it does fit well with the build it yourself idea.
I was looking at the BOM of materials and it came to about £40 I think (I've got the spreadsheet for it all somewhere). The designs for the PCB are opensource and we can have them printed anywhere. Might be worth doing a run of them?
Geedle.
Old 12th July 2017, 09:14 PM
I have never found a decent Source for LowVol PCB manufacture in the UK.
US has them in abundance
With a BOM of £40 and a low price PCB it would be a gr8 project.
Old 29th July 2017, 03:08 PM
Hi,
I found a couple that I am sure are China based given the cost and lead time. But it does sound like a great project.
I think for IVA it would present a problem as the immobiliser element of the standard setup would be lost. Easy enough to get round I think. 2 circuits associated with starting need to be disabled. Can't be too hard.
Geedle.
Old 5th August 2017, 06:39 AM
where in the IVA does it say you need an imobaliser?
Old 5th August 2017, 09:44 AM
I'm reading section 13A. But on re-reading, does the steering lock + ignition switch suffice? That said, last time I read, I was sure I found something about the requirement to disable two circuits.
Old 7th August 2017, 07:06 PM
Two Methods of Disabling.
So yes locking the column and needing a KEY to start are two accepted methods.
Old 7th August 2017, 09:51 PM
Ahh - I had assumed (wrongly) that the transponder found in keys and the phisical key were the two. That makes it easier!
Old 7th November 2017, 10:49 AM
norton norton is offline
Did anyone go down this route in the end? Assembled megasquirt ecu’s aren’t much cheaper than Emerald ecu’s these days which goes against the on a budget spirit of things.
Old 7th November 2017, 09:53 PM
still an idea but having not touche a car "project" in 2 years its not going to be top of my list..
