Old 1st May 2018, 09:48 PM
Ianr Ianr is offline
Brilliant - welcome to the club - worked for me as well on loads of rusty bits for my build
Old 2nd May 2018, 06:42 PM
RandyBMC RandyBMC is offline
Wow - I've been toiling away with a parts washer, pressure cleaner and wire brushes! That looks a lot easier.
Old 30th July 2018, 10:05 PM
SteveH1 SteveH1 is offline
So ive a serious pain in my face at the moment cleaning and painting and reassembling the engine
Before
Current
Im also doing a coil on plug upgrade as i had all the parts i needed so it didnt cost me anything
Old 1st August 2018, 07:17 AM
Some more progress
Im also going to do some kind of diy coolant reroute
Havnt got it fully figured out yet
This part fits nicely of the back of the engine like so
Old 6th August 2018, 08:27 PM
Finally got the engine back together mostly
Old 18th September 2018, 07:22 PM
Next up was to mount the radiator to the chassis
I was originally going to use a spurious golf rad which was not great looking to be fair then coolex had nice ali rads for a polo for quiet cheap at the national kit car show so i picked one up
I Got two brackets bent up for it to mount it to the chassis
Clamped in place to check everything lines up
Checking the fit of the nose cone
I decided to add two new pieces to the chassis rather than drill through the existing chassis
Old 18th September 2018, 08:37 PM
Then i started on the piping for the cooling system which i picked some of it up at the kit car show
And some of the rest of the parts came from aliexpress
I picked up the wrong size pipe so i need to get some more 32mm id piping
Then i started on the wiring which is a whole other can of worms
Old 7th August 2018, 05:34 AM
Scrubbed up nicely
Old 19th August 2018, 08:56 PM
bentovey bentovey is offline
Just read you entire build, great work!!
I’m just starting mine (mx5 just stripped)
Keep up the good work, and posts
Statistically only one in seven dwarves are happy
Old 18th September 2018, 10:25 AM
So ive got a bit done recently
First i built an spacer for the new rear coolant pipe for the reroute to move it out from the block
Then i filled in the the hole in the side coolant connector
Used a 20 cent to stop the epoxy running into it
Filled with epoxy
The hole was a feed for the interior heater so is not needed
