			 Hello all,
	I just received an OBPKC003 pedal box, and there is no linkage for the throttle pedal. Has anyone used this set up? I am using an MX5 (1993) for a donor. The last page of my build shows photos and poses the question. See here: http://locostusa.com/forums/viewtopi...3774&start=195 Help! Thanks in advance.  |
			 I had to modify mine, wasn't happy just couldn't see how I could get it work as was
			 Untitled by mjb22001, on FlickrI raised the pivot point and welded a bit on the bottom so the cable pulls from the bottom. not sure how it was designed originally, there may be better solutions but I couldn't make it work in my car as was
	Build Cost so far £xxx (Given up adding it up) - She Starts!! Build Thread Here: http://www.haynes.co.uk/forums/showthread.php?t=5501  |
			 Thanks Mike - I worked out a solution.  We'll see if it works!  I posted photos of the start in my build thread (see my signature).
	My build: http://locostusa.com/forums/viewtopic.php?f=35&t=3774  |
			 Buttoned up the pedal solution today.  Take a look at my build log's last page.  Input is welcome!
			 Looks great.
			Annoying that for an expensive item there isn't a stock solution to attaching a throttle cable.
			 Thanks - totally agree!  I requested help on it from Rallynuts and OBP, and just got the PDF of them drilling a hole in the end of the pedal.  Wilwood has a complete bell crank bolt-on solution.  As you said, for the money, I would've hoped even if I had to pay a little more I could've gotten a bolt-on solution.
			 I remember finding that pdf. looked at it and thought, that's no use to me! I would have paid a bit extra for a solution considering the faff I went through. I'm still not happy with mine as its no really adjustable. I have just enough pull to fully open the throttle
			 How is your pedal travel?  Mine feels like it is too long.  I remember reading something about that in Stot's build as well.  I know Neil Cropper had made a smaller throttle body wheel, but I haven't heard if it worked.  That'll be on my list after getting the car up and running...
