![]() Not a bad fail - well done! To reduce heat I wrapped the exhaust manifiold and cat completely in exhaust wrap about 50mm wide, worked a treat and simple to do. I got some stainless steel ties to keep it in place, don't think plastic would have worked.
My build blog here http://ianhaynes20.wordpress.com |
![]() yeah i would be happy with that, I think my fogs is correct. Fuelling is always a bugger .
Will you get it back there in time for the restest?
![]() So my new fog light is here and just needs fitting. I have ordered a set of carbs which should be arriving soon. I am booked in at Bogg Bros on 12th June and I'm hoping to get another IVA test at the start of July but I will ring up to book this next week. So hopefully I will be on the road later this summer.
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() |
![]() Fingers crossed, been a long haul
![]() But if the weather is like this ( assuming you have the baking sun) summer could be fun
![]() Good luck with IVA retest.
Car looks real nice. |
![]() So I had a very successful day at Bogg Bros today. I changed my fuel pump for a brand new pump I had in stock. My pump was behaving weirdly after the IVA test where it was running constantly at times when it shouldn't have been. The new pump seems to have resolved my issues.
One getting the Bogg Bros the car was running very lean, after trying a few different jets, balancing the carbs and adjusting the floats it was all nicely dialed in. The car is now making 120bhp and weighs in at 630kg so it should be pretty pokey to get started with! I have fitted my new fog light but I need to order a new electrical connector as the new fog has a different connector annoyingly. I will be booking my IVA retest this week so I will keep you posted on when the new test is.
![]() So good news! I had my IVA retest today and it was a pass!
It only took 20 minutes to check the fog light, set the headlights up and check emissions. There was a lot of discussion about emissions as he had tested me on the stricter 0.5% CO limit and said I had failed until I pointed out I should be tested on the 3.5% as my engine is 1993. I need to wait for a cheque book to arrive before I submit my registration paperwork as the DVSA only accept payment through either cheque, postal order or shillings ![]() I have Blyton park booked for Saturday 14th August so I just need to fit a new gearbox output oil seal, refit my proper steering wheel and refit my dB killer this weekend. Thank you so much everyone for your support over the past 12 years. I really couldn't have done it without you and this forum.
