#641
You don't live in Alfreton do You?
Astra vxr powered Roadster in progress
300bhp hopefully |
#642
Nowhere near I'm afraid - North Norfolk
My build blog here http://ianhaynes20.wordpress.com |
#643
Quick update. I still enjoy my car when its sunny. I got a 3D printer recently and designed/made some custom hubcaps.
Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 Last edited by Stot : 2nd July 2020 at 11:21 AM. |
#644
Lovely detail, as always. This thread is a regular point of reference for me, and I also see it coming up on other forums as a great resource.
#645
cool..
they look like polo wheels??? got a 3d printer myself about 3 weeks ago and its done a lot of work!
#646
Sounds about right. I had 15" G60 wheels on it originally but wanted 13" for more comfort and also to be able to fit stickier tyres at a lower cost.
They fit over the MX5 running gear fine. Cheers Stot
1.6 Mazda B6 : Garrett TBO339 : 420cc WRX Injectors : FMIC : Microsquirt V3 : LC-2 Wideband : Toyota COP : 1.8 ATB LSD Build Started Jan 2013 : OTR Aug 2014 : Still OTR June 2024 |
#647
10 years on and it still needs tinkering. I did the head gasket, cam seals and water pump this week chasing a couple of leaks.
![]() Also the turbo burnt through my bonnet heat shielding, so a new method was needed short term... ![]() Which actually worked amazingly well! But I have upgraded to a blanket. ![]() Maybe see some of you at Malvern. Cheers Stot
#648
Good to see someone still about. I'm afraid I am in darkest Norfolk so it's a bit far for me, hope you have a good day
#649
Well there is always something to do.
For example, I fancied a boost gauge then remembered I don't do anything simple like 'buy' a boost guage, so ended up buying an ESP32 dev board with a round screen and coding myself up this to connect to my Megasquirt. ![]() Click for a video. Shows boost, vac, Coolant temp, AFR, Advance and has indicators for Warm up enrichment, Afterstart enrichment, Table switch status and Launch control status. ![]() I added a passthrough mode too so I can connect my phone to it via wifi and MSDroid can connect to the Megasquirt wirelessly for tuning on the go. Cheers Stot
#650
Well done - always thought you never did anything simple when complex would do.
