Old 12th February 2009, 12:18 PM
fabbyglass
Car up for mot next week ...........
Old 12th February 2009, 12:46 PM
shadowcaster shadowcaster is offline
Good luck, I hate MOT time, got the Disco going through next month.
Cheers Rich
It does not matter how slowly you go so long as you do not stop.
Confucius Chinese philosopher & reformer (551 BC - 479 BC)
Old 12th February 2009, 01:22 PM
I'll try to get it to you by this weekend.
Old 12th February 2009, 10:13 PM
onedayTM onedayTM is offline
Hi Bonzo,
a question relating to donors, do you need to prove ownership, I am hoping to use a 1.8 zetec out of an xr3i I owned but it was written off after accident. Stripped it and then scrapped it, didnt keep any documents. Also bought sierra parts off mike B without history or docs. goin for Q plate will I have problem with SVA.
tony
Old 13th February 2009, 11:07 AM
Default Proof of ownership ?
Hi Tony.
No,i don't believe that you need to prove ownership of the donor parts.
As many peole wish to obtain an age related number plate for their build the most simple method is to provide your local DVLA with the donor cars V5 document.
It is then easy for them to check that the parts used came from a single donor.
I believe the best way to do this is to obtain a V5 in your name & keep the donor vehicle on SORN until you are ready to register your build.
As you are going for a Q plate you should have no problems. The donor parts can be a mixture of parts from many different cars.
I would avise that you keep any reciepts for the parts bought though.
One possible issue may be proving the age of the engine.
There is some talk about this subject. It would appear that, if you cannot provide proof of you engines age, your build will have to meet the latest emission regs.
Some people have used Burton powers engine build code list to prove the build date. Others have written to Ford for engine date confirmation.
I think it is simply a matter of how your local DVLA work & how anal they are.
I am by no means an expert in this area. This is just my personal take on things.
I am sure that I will be corrected if I am wrong.
Old 13th February 2009, 08:24 PM
cheers for that bonzo,
tony
