![]() Cheers Spud69
can i pop over at the weekend? few things i think i need your advice on. i will be doing the zetec after iva. its the sump mod thats got me sweating , one wrong cut etc etc ![]() ![]() cheers andy |
![]() We're off camping at the weekend Andy, but if you pm me with you're address and mobile i'll drive over tomorrow or Thursday night weather permitting.....Any excuse to get out.
![]() It has been said on the forum that VOSA may re-inspect a car later so as too check it is still as IVA'ed previously ie not modified further,hear say or not it would be a pain.
![]() Quote:
![]() Quote:
![]() ![]() ![]() i,ll pm the address. cheers andy |
![]() ok all you wise ones, a few questions for you.......
will a set of ZX9R bike carbs work with my cvh engine ? either before iva or after? then when i "need" to swap my engine for a 2ltr zetec will these carbs be ok for the new engine etc? your advice sought & welcomed. ![]() cheers andy |
![]() Why not IVA the set up you have,ie bog standard engine and carb that way you will not have to make or setup anything out of the ordinairy,like making manifolds and buying jets and the like.
Carbs have been discussed on here somewhere and I think zx9 or zx 600 were preferable but dont quote me on it ! Cheers. |
![]() Hi Andy
I am far from an expert in this field but here are my thoughts for what they are worth. Being as your donor was a darn fine runner, I would be inclined to leave the CVH as standard till you have had your IVA. ![]() To fit the carbs onto the CVH you'll be needing to make an inlet manifold to suit. I would imagine that the jets may need replacing or fine tuning for the engine to run smooth & meet emission targets. Do you really want the hours & hours of work fine tuning the CVH engine just for temporary use. When you change to the Zetec engine, you'll need to start from scratch all over again ![]() The carbs set up for the 1.8 CVH are not likely to run so well on a 2 litre Zetec. A fair bit of power difference between the 2. I think the carbs you mention will be OK for either engine but probably best suited to the Zetec unit. ![]()
![]() ZX9R carbs will work fine with both engines. You'll need them rejetting on the Zetec though as it flows more air/fuel through the head ( I think most people just re-drill the jets up to 1.7mm). Obviously a bespoke manifold will be required for each engine. This isn't hard to make, but if your not happy making one, companies such as bogg bros will sell them.
Depending on your engine management choice, your going to need some sensors. Now I believe, that some early ZX9R carbs came without a TPS and would require a custom bracket and a TPS sourcing. So its just easier to get a later model set, that includes a TPS (assuming you need one) I don't know if your 1.8cvh is pre cat or not. If it is, then putting carbs on won't make any diff to the IVA. |
![]() Quote:
![]() as my plan is to go zetec asap then theres no point in spending time & money setting up the cvh / bike carbs at this point, UNLESS if the bike carbs make the cvh more responsive & so more enjoyable to drive with a relatively low powered engine , as i know my cvh engine is in good fettle & have full service history on it etc etc then it may still be worth considering, ![]() decisions decisions ![]() cheers andy |
