Old 24th May 2009, 06:00 PM
Chris_ Chris_ is offline
Originally Posted by rmccomiskie View Post
Looking at the E36 front uprights, BMW didn't mind bolting a 'doodah' to it. The strut is attached to the back of the upright with 3 bolts. That strut has a lot more leverage than the top wishbone would have. It seems to me that a properly designed 'doodah', one that provides the desired geometry, would be quite strong and perfectly safe.
Bob.
I wasn't saying ot for the strength side of things, more, as you say, the geometry side of things.
Not sure i'd fancy knocking one up with a bit of plate and a MIG, and certainly not two identicals
Chris
PS, E30 & E36 diffs are either small or medium case. The large case goes on the bigger models (5, 6, 7 series) oh and the rear cover is interchangable between e30 - e30 smalls and e30 - e36 mediums. (ie. not small to medium or vice versa)
Old 24th May 2009, 08:06 PM
rmccomiskie rmccomiskie is offline
Chris
I agree. Making two mirror image adapter brackets would require some very precise measuring and workmanship. Some kind of jig would be needed to hold the critical parts in alignment. An advantage of this approach is that you could change the geometry at a later time by fabricating another set of brackets. With enough adjustment built into the wishbones, it would be relatively simple to swap street geometry to track geometry.
Let's see if I understand you correctly. The E30 and E36 small diff rear covers are interchangable and the E30 & E36 medium covers are interchangable. And the small cover won't fit the large case. Right?
What do you know about the Z3 diffs? It looks like they have yet another version of the rear cover. I think it's the same diff. Is the cover also interchangable?
Bob.
Old 24th May 2009, 11:43 PM
Thats right as far as i am aware.
The Z3 uses a nearly identical rear end to the E30. Except with 5 stud hubs, bigger brakes, some new diff ratios and the option of a very tasty 'torsen' diff.
The diff is indeed the same except with that nice finned rear cover. This cover should fit any other similar aged medium cased diff. E30 E36 E34 (small engine 5 series) etc.
Any more questions??
Chris
Mind you, i am just about to go and double check about all this.
