Old 22nd June 2009, 09:55 AM
gus's Avatar
gus gus is offline
Propman, I take it from your previous posts that you are from NW propshafts.
If so this company is excellent. Ordered a prop at 11.30am on Thursday. Received it by 12 noon Friday.
Looks brilliant and fitted into the car perfectly.
Can't recommend these guy's enough.
Mark
Old 22nd June 2009, 10:14 AM
Prop Man Prop Man is offline
Thank you Mark.
Hope the rest of you build goes as smooth.
Michael
Old 22nd June 2009, 10:20 AM
so how do i contact you Michael when i need to place the order?
thru this forum or direct etc ?
Old 22nd June 2009, 11:26 AM
gus's Avatar
gus gus is offline
Alright Andy.
Rather than put Michaels contact up incase spam etc etc
Do a google search for northwest propshafts.
First result you'll see. Service is excellent.
Mark
Old 22nd June 2009, 11:29 AM
Originally Posted by gus View Post
Alright Andy.
Mark
Thanks Mark thats great,
thats why i asked as don,t want to put info on a public forum.
Old 23rd June 2009, 08:09 PM
can i ask a basic possibly dumb question..........
do i need to supply my donor propshaft to the company that makes me a new shortened version?
sorry if its basic but i just don,t know the answer
Old 23rd June 2009, 10:32 PM
As long as you give the company the correct information
Gearbox configuration (spline or flange sizes)
Diff Cinfiguration (flange sizes)
Length from Diff flange to gearbox oil seal or flange or
lengths between any fixed points ie Diff, Centre Bearing and Gearbox
Torque transmitted through the shaft or BHP so shaft can be built to the right spec.
The propshaft company should be fine with that.
Although Cheaper shafts can be made from good donor shafts.
Old 23rd June 2009, 10:39 PM
Thanks for the info Prop Man,
tho i would have to factor in the cost of getting the shaft to you,
so how much cheaper if i supply my donor shaft?
thanks
Old 14th July 2009, 09:54 PM
Where are you Propman??? I have cash on the hip and awaiting for you too log in to check your mail!!!.......????
Old 14th July 2009, 10:01 PM
Spikehaus....... PM sent to you
