View Poll Results: Which method would you use to cut your chassis steel?
I Wouldn't, I would buy a chassis pack 12 23.08%
Hacksaw 7 13.46%
Chopsaw 18 34.62%
Bandsaw 8 15.38%
Other 7 13.46%
Voters: 52. You may not vote on this poll
Old 7th July 2009, 06:37 PM
mark mark is offline
Originally Posted by scoobie View Post
Hi Chaps,
I'm *still* in the planning/saving stages at the moment, and I'm thinking about my options for the chassis steel. I will either buy a chassis pack from armoto, or cut the steel myself.
The question is, if you were building your chassis again, which of the options would you choose?
Thanks chaps
Personally i used a rage 3 mitre saw and thought it did quite a good job too
As somebody mentioned though you do get showered in hot pieces of metal
But i dont think there is a quicker way of cutting a compound mitre so quickly and accurately
Old 7th July 2009, 06:56 PM
fluxcored fluxcored is offline
Where accuracy is a concern I use a cold cutoff saw - the Makita one is probably the best all around, it's got a good solid base.
Mostly I use a 115mm angle grinder with a 1mm disc and a file for quick and dirty operations. I found that I can be as accurate with this method as using my cold saw.
I would love to have a bandsaw, but just cannot afford one. I'm thinking of building an old skool power hacksaw for cutting thicker stock.
Laziness is a sign of sheer genius!
