View Poll Results: Which method would you use to cut your chassis steel?
I Wouldn't, I would buy a chassis pack 12 23.08%
Hacksaw 7 13.46%
Chopsaw 18 34.62%
Bandsaw 8 15.38%
Other 7 13.46%
Voters: 52. You may not vote on this poll
Old 8th July 2009, 06:12 AM
ACE HIGH ACE HIGH is offline
Default steel cutting method
A hacksaw,cut each end 1/2mm oversize and true it up.Buy only the best blades,24 teeth per inch would be my choice but 18 OK.I have over 40 years of experience as a fitter /welder with all sorts of fancy expensive gear,and by the time I stuffed around setting it up and cleaning up the ends I would have done the job.Hacksaws can be very dangerous,dont lean on a blunt blade,if it fractures and breaks it will spear back at your face and neck and chest,always wear safety glasses with a hacksaw and throw away blunt blades, and most importantly,there are only 2 types of blades,the best and rubbish,pay extra for good blades.I consider so called chop saws VERY dangerous,but I am a little behind the times here,I would only consider one of these from a top brand,Bosch,Fein,Makita,Hitachi,AEG etc.Life is a little cheap in China.David
