Old 3rd August 2009, 10:25 AM
geeman's Avatar
geeman geeman is offline
Default Aluminium floor
Well im planning on using an aluminuim floor, but not completely sure as to what thickness aluminuim i should be using. I was thinking 2 or 3mm. Also i was going to use some 40x3mm strip as well for seat montings when it eventually comesto it. I was also wondering if i should use 3mm tread plate as i think it would give a nicer effect and is hardly any more. I was planning on ordering a 2x1m sheet from parkersteel. Also on the inside for interior i was hoping to do somthing similar to the digram on pg116 but was wondering if i should use thim aluminuim as opposed to mdf or plywood for the inside layer.
Also im hoping this will be my last parkersteel order so is there anything i should order now incase i need it, as im not sure where else ill need aluminuim/steel as i dont want to fork out for another delivery charge later.
my build pics
Old 3rd August 2009, 01:54 PM
Tilly819 Tilly819 is offline
I used 1.7mm for the floor and 0.9mm for the reast of the body work
Tilly
Old 3rd August 2009, 09:11 PM
I used 2mm 5000 series aluminium (5251 I think). Its twice as strong as a sheet of 1000 series aluminium and around the same price. Its tempting to just ask for a sheet of aluminium, but you might end up with something sold for takeaway trays (1050) versus the aluminium built for aircraft and marine craft (5251).
Old 3rd August 2009, 09:14 PM
Beardy_John Beardy_John is offline
IMHO I wouldn't use alu tread plate for the floor. Its very soft material to start with to get the tread pattern rolled into it. Your best going for 5000 or 6000 series alloy
www.beardyjohn.com Build blog and associated ramblings (Updated - 17/07/09)
Old 3rd August 2009, 09:30 PM
snapper snapper is offline
You have to think that your bum and your legs are only a couple of inches from the floor, on one of the Rally programs one Co driver had a very close shave when a steel reinforcing rod went through the (steel) floor, seat and his race suite but stopped short of entering him.
Old 3rd August 2009, 09:37 PM
The more I think about it, the more I like the idea of a steel floor. I have no want to be "entered" by any sort of rod
Old 3rd August 2009, 09:45 PM
sorry to hijack the thread but can i ask ........
i have some sheets of stainless steel, 1.2mm thick, nice quality ( its the stuff used for kick plates on fire doors in M&S )
would this be ok to use for my floor?
thanks
Old 3rd August 2009, 09:46 PM
do you know what grade of stainless it is?
Should have also asked, are you using alu rivets? You'll run the risk of galvanic corrosion between the alu rivets and the stainless sheet if there is any salty contact (i.e. winter driving). Next thing you know the floor might fall out
Old 3rd August 2009, 09:53 PM
sorry don,t know what grade the stainless is, was given it from a shop refit
is there any way around the corrosion issue? or should i stop being a tight git & buy some decent ali ?
thanks
Old 3rd August 2009, 10:09 PM
The best thing you can do is insulate the two surfaces so they don't contact. glob of PU before you stick the rivet in would probably work. So long as you don't do a lot of driving in salty conditions, it might never happen. If you've got it laying around give it a go, worst is you have to drill it out and replace it.
