Old 8th August 2009, 11:28 PM
davidimurray's Avatar
Default Cooling Fan
Anyone used one of the the budget fans from SVC?
http://www.s-v-c.co.uk/prod_fans.html
The price seems fantastic compared to other products and at that size I reckon it would fit nicely inside the front frame. I plan on setting my fan back from the rad so as to avoid the 'dead' spot found when mounting directly to the rad. I will then make up a shroud to help direct the air from the rad to the fan.
Just wondered if anyone had tried this fan and whether it was anyone good?
