![]() ahh i,ve got one of those pot things,
![]() or is it a ikkky thing??? ![]() ![]() andy ![]() |
![]() My photos are not that bright but here are a few shots of my brake line and fuel line.
Al
1969 Amx 2004 Passat 1.8T 5Spd 4Motion Haynes Modified Super 7 3.4L V6 www.lotussuper7replica.com/ |
![]() Raceral....
i like the "sunken" handbrake lever ![]() & is that a brake bias valve behind the handbrake lever? andy ![]() |
![]() Thanks HandyAndy, the handbrake is off a Honda Civic I found in a wrecking yard.
And you are also correct on the adjustable bias valve. Al
![]() That Pinto pic threw me as well,I remember taking it of the drivers side inner wing and the carbs on the other side.
![]() Old thread I know - but it's where I am now!!!
Looks like most people just drill into the chassis rails (and rivnut?) to secure their p clips? Does the 'perforated strip' idea mentioned in The Book mean "welding on a strip of 1mm plate that you've drilled a load of holes in" - like the pic in Dogwoods post (page 1 of this thread). And do most people not bother with this approach? Just want to make sure I weld everything necessary before painting!!!
![]() I used 40 x 3 , drilled every 100mm with 3mm holes for pop rivet's ,top and bottom of tunnel.
![]() 40mm wide x 3mm thick flat steel strip.
