Old 24th August 2009, 08:39 AM
I have used a company called Bearing Services LTD ( BSL ltd )
They are a national chain & more often than not come up trumphs for obscure bearings.
As Ash has said, it is well woth measuring the OD & length of a bearing, then finding out if one with a smaller or larger ID is available.
Folk probably know this but the numbers etched onto the face of a bearing usually contain the type & size of the bearing
Bearing supplyers are also a good source for oil & grease seals, again the numbers on them are often the type & size
