![]() While were on the subject of wheels, i found a set of 15 in alloys near me for aout £150, but the seller has only told me thay have come off a peugeot 106 so it has a bigger bore(65.1mm) and a offset of 20mm(i think) which im not sure if would be suitable?
if not, i have found many other alloys mostly which are 17in ones. I know that for optimum geometory, 15 in alloys are required, but would i encounter any problems using bigger wheels? Thanks.
my build pics |
![]() Quote:
![]() Sean |
![]() Peugeot/Citroen have the same PCD as Ford on the Sierra with four studs,I am lead to believe that the later wheels on the Focus etc are different.
![]() just to add a bit peugeot/citroen have the same pcd but have an et15 off set . this would mean they would stick out a bit further
![]() Quote:
![]() Sean |
![]() Quote:
gosh .......i thought ours where overkill at 260mm vented .................................................. ................................. that will be some real stoppiing power in a roadster hope your harness,s dont have a crutch strap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ![]() cheers les g ![]() |
![]() Quote:
![]() They are bloody heavy though, I might look into getting the 2 piece type, with the alloy inner bell. If they turn out to be a bit much then I may swap to smaller ones, but I also like the look of big brakes Sean |
