Old 4th September 2009, 01:26 PM
squbti's Avatar
squbti squbti is offline
hmmmm, let me see so SW1 is cut to 40 & 23degr ok , how does that make the frame lean 71degr .i dont get it but i do see how the length is different when something is at an angle .... but the book shows the length & not the hight of the frame on page 46 but i get that so thats fine however im still not sure about the angels.
Samy
Old 4th September 2009, 01:58 PM
Samy
Samy,
have a look at Ash G,s thread titled "Build photo,s" as there are some good photos from lots of angles & maybe you can see how the support frame sits,
tho depending on your preference you might want to have the outside support on the nearside of the side rail for fitting side panel/scuttle placement.
hope that help.
Old 4th September 2009, 06:04 PM
squbti's Avatar
hi andy , thanks for the help. ash has got some really good photos it a great help , however the thing i´m still confused about is how cutting a pipe at 23degr makes the remaining angle 71 . i know how & where the frame is going to sitt but i just dong get the math here(was never my strong side)
Old 4th September 2009, 07:41 PM
to be honest its not that critical as long as the steering colum ends up centeral to the drivers seat and the frame is roughly where the book tells you to put it. the scuttle goes over the top of it so once the car is finished you will never see it.
when i did mine i found that the angle on the right hand leg (sitting in the drivers seat) of the frame was wrong. to cure it i placed the left side on the transmission tunnel where it was meant to go and let it natrually pick its spot on the right side. i then just filled the small gap where the angle was out on the drivers side with weld.
Old 4th September 2009, 08:29 PM
squbti's Avatar
so i guis i´m just going to tack it in place & see how it looks & stop thinking too much or else i´ll get nothing done
thanks for the help
Samy
Old 7th September 2009, 08:18 PM
squbti's Avatar
hi all, just tacked the steering wheel frame in place but not so sure if it´s in the right place , i did sitt in the driver seat & it feels preaty centered.anything i can do to make sure it´s good before i fully weld?
Samy
Old 7th September 2009, 08:30 PM
squbti's Avatar
i dont know who it was that had posted this picture but are these measurements corect? this is what i used for my steering frame.
Old 7th September 2009, 08:37 PM
dogwood's Avatar
dogwood dogwood is offline
Just to confirm what Ash said.
It is not critical as long as it's central to the driving position.
I made the bolt slots longer so I have more up and down adjustment
I also made mine bolt in rather than welding.
HTH David
