Old 5th September 2009, 04:43 PM
Jeze2903's Avatar
Jeze2903 Jeze2903 is offline
Unhappy Rear wishbones....HELP
Hi
Does anyone have a plan view picture of the rear wishbones fitted to the chassis. My car is sitting wrong and after hours of measuring I seem to have one of the rear wishbones back to front.
Old 5th September 2009, 05:17 PM
Perhaps this picture will make the orientation a little clearer
This is the nearside rear wheel, photograph taken looking at the back of the car .
If memory serves me right, the book states that the single arm of the lower rear wishbone faces the front of the car.
Old 5th September 2009, 05:47 PM
Jeze2903's Avatar
Hi
Thanks for that, got it all sorted now...What a numpty I am!!!!
Thanks again
Old 6th September 2009, 12:40 AM
sorry to be a stick in the mud ronnie you have that wishbone on backwards. the brace at the hub end should face forward.
Old 6th September 2009, 08:53 AM
drury318 drury318 is offline
I have my wishbones on the same as Ronnie, I was going by p74, there is a picture showing it that way round, am I wrong?
Dennis
Old 6th September 2009, 08:54 AM
Talking Damn, blast & bother
Oh bummer
Thats another re-read of the book
All seems to line up well. I can't remember if the wishbones are made symetrical or if they are made with an offset.
If they are symetrical I would assume that the placement of the wishbone is stress related.
On a brighter note, at least they are just test fitted
Old 6th September 2009, 09:43 AM
TSM Locost's Avatar
Default Confusion
Unless I am mistaken the picture ( p74 ) is opposite to the text on p73.
EDIT. Check the Drg on page 10, arms are made symetrical if not you would need 2 jigs as upper front needs. Brace should be under compression when acceleration. Pic must be wrong. OOOOOOOOOOOOOOP's
Be Lucky, Mike.
Old 6th September 2009, 10:52 AM
as tsm says the stress from forward motion should go into the brace at the front down to the rear sus bracket. the design is intended to make the wishbone stronger in forward motion should you hit pot holes curbs etc.
Old 6th September 2009, 02:00 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
my 2p if i read the book amendments correctly bonzo has it correct it says:
"the lower wishbones need to be installed with the cross brace angled from outside rear to inside front"
So are you guys saying this is wrong or am i being thick?
Ray
Old 6th September 2009, 06:31 PM
Hoybi's Avatar
Hoybi Hoybi is offline
Default not really important
allow me to give my opinion on the matter.
The amendments state that the text (page 73) should be installed with the cross brace angled from outside rear to inside front. This corresponds with the picture on page 74.
But is contradictory to the drawing of page 10.
Either way, the brace is meant for the triangulation of the lower wishbone and it doesn't really matter how it is orientated.
However, it would look silly if you have the two mounted differently.
From the viewpoint of mechanics it would be logical to have the brace being stressed rather than compressed while taking loads (say driving). Mind you, I wouldn't like to sit in the car when the brace breaks, no matter how it was mounted.
Eddy
www.alfaprojects.be
