Old 11th September 2009, 03:55 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Thats the one i was having a senior moment
Old 11th September 2009, 07:18 PM
squbti's Avatar
squbti squbti is offline
i was thinking of taking some washers & cutting them in half & then just weld them on the open pipe ends.
Old 11th September 2009, 08:08 PM
Call it a CRAFT moment Ray,Cant Remember A F***ing Thing.
Old 12th September 2009, 11:27 AM
uggy uggy is offline
Default flatting the ends
try getting a piece of 50 x25 flat mild steel 100 mm long drill a hole in the middle 25 mm in diameter then cutting it in half so you end up with two pieces 50 mm long with half a hole in the end. place one piece on a press bed put wishbone on top then the other piece on top of the wishbone with 5 mm past the bottom of hole with the rest of the former over the plate then press it. should leave a round profile on the end of the pipe with the very end flat against the plate. try some test pieces first
Old 13th September 2009, 12:56 PM
Nice idea, but I don't have a press. I think I will just use Waxoil
