Old 14th September 2009, 08:32 PM
my headlamp brackets are 12cm from the chassis rail to the center of the hole in the bracket, this then makes the holes between the 2 brackets 90cm wide, tho it depends where on the chassis you weld the brackets, mine are welded above the upper shock mounting bracket.
hope that helps.
