Old 14th September 2009, 08:05 PM
Originally Posted by flyerncle View Post
Sean,If you look at how the suspension is set up the tube is clamped in the bracket and the bush turns on it, if fitted correctly the bush should not rotate in the sleeve of the wishbone and that would defeat the object of the poly bush as it is meant to rotate around the stainless tube.
That would be why the sleeves are a tiny touch longer then
