Old 16th September 2009, 08:54 PM
squbti's Avatar
squbti squbti is offline
Default seat hight
hi guys, so i´ve just taken out the seat runners from my sierra & was wondiring if there is any thing i should consider about the hight or position of the seats, like how high off the floor can they be ? (i have fiberglas seats)
thanks
samy
Old 16th September 2009, 09:05 PM
depends how tall you are
& depends on whether you,ll be fitting a windscreen or an aero screen, that may sound obvious but the couple of cars i,ve been a passenger in i had struggled to see over the aeroscreens (totally darkened screens), so i,ve raised my seat rails by 25mm above the lower chassis rails,
i,m 5ft 8in tall .
Old 16th September 2009, 09:09 PM
Good things,small packaging ?
Old 16th September 2009, 09:12 PM
are you talking from personal experience Paul ?????
gotcha
Old 17th September 2009, 05:11 PM
squbti's Avatar
so its deferent from person to person then. are there any rules as far as sva & such?
Old 17th September 2009, 05:31 PM
yes there are rules for the IVA, but more to do with the position of the seatbelt/harness mounting points(upper ) in relation to the position of the seat & now i believe seats must have some form of head rest area so the old style short back seats wouldn,t pass etc.
As long as the seats are securely fixed i don,t think you,ll have a major prob with the regulations, after all its a safety point that you can see over the scuttle
Old 17th September 2009, 06:18 PM
squbti's Avatar
yeh, i think the rules are the same here in Sweden but i think its ok to use the short back seat. i have the short back seat & will have head rests on the rollbar, should be just fine.
Old 17th September 2009, 09:41 PM
im 5 10" and i put an inch spacer under the runners on fabbys wide seats
Old 18th September 2009, 09:32 AM
fabbyglass
Seat height is a user thing but like said up there somewhere you have to be able to see over the scuttle and aeroscreen(if fitted)...Trick is to sit as low as you can and still see where you are going. Non of this arms out straight malarky either as you will never steer the thing...close like a rally car so you can control the wheel when the back steps out
Old 18th September 2009, 03:46 PM
Andy it's all in proportion, 6ft 2in in height size 11 feet say no more !
(was being kind to you )!!!!!!
