Old 18th September 2009, 09:32 PM
thanks David, yes that diagram does help, yes please to a pic as long as you don,t get wet
i,ll give it a go tomorrow, if it works then great as my wallet can breathe a sigh of relief for a little longer
thanks everyone for your input, much appreciated.
Old 18th September 2009, 09:38 PM
dogwood's Avatar
dogwood dogwood is offline
Andy.
Can you send me a PM tomorrow to remind me.
Coz I'm bound to forget.
Yea, Yea...Alright so I've had a sherbert or two ok...
Old 18th September 2009, 09:41 PM
no prob, & thanks
Old 18th September 2009, 10:04 PM
Place in Team Valley can balance it for you !
Old 18th September 2009, 11:16 PM
Land Locked's Avatar
For those looking for a way to lose the huge rubber "do-nut":
I put a gearbox from a sierra into my old cortina many many moons ago. Found the cortina yoke didn't fit the sierra box, so went back to the scrappy with the box and raided his propshaft collection. Found that the yoke from a hilman vogue fitted the sierra box in terms of the splines, just needed to be shortened by about an inch. Even the UJ's matched.
Back to the original question, if you get it lined up properly and your welding is good there should be no problem except possibly/probably balancing.
Regards (The mad Sarf Efriken)
Old 19th September 2009, 10:34 AM
les g les g is offline
Andy
100% agree with all these guys
a flexible joint at both ends is a must and diy props are achievable
you just got to weld it true
and an old trick for when its on the car
if you have a slight vibration put a jubilee clip around the shaft and run it .if no better rotate it slightly etc etc until the vibration goes i have seen up to three jubilee clips used to smooth out a vibration
cheers les g
PS. it wasn,t my welding LOL
Old 19th September 2009, 11:08 AM
Neil P Neil P is offline
I made mine, it's fine. Rubber donut fits easy in a chassis made for an MT75 'box.
Neil
Old 19th September 2009, 11:44 AM
Neil
Good - because that's what I'm planning on using.
Is there plenty of room for brake and fule lines, plus the leccy??
Sean
Old 19th September 2009, 06:11 PM
dogwood's Avatar
Hi Andy
Pic's as requested....
HTH David
Old 19th September 2009, 07:46 PM
I can't believe that that Andy made you take the top off of your tunnel for that photo.
Looks a propper job David ( Excuse the cheap pun )
Given me a clue to the way forward that's for shure
