Old 25th September 2009, 06:05 AM
Matthew Matthew is offline
My donor was a 2.0L Ghia with fuel injection and ABS so I think I probably have the most bloated wiring loom in existence. Took me nearly a day to strip the various parts from the car and lay them all out, then another day to separate everything. I've pulled the loom completely to bits and removed all the unnecessary wires - some things like the indicators were bundled together with the power windows and central locking which I don't think I'll be needing. After stripping out the bits I didn't need I taped it back roughly together to keep things tidy.
I'm not at the stage of putting it into the car yet, but like most things It's just a case of being methodical and checking everything as you go along.
I do have an electronics background though, and many moons ago spend a couple of weeks on a course that taught how to build looms to military spec so regard the wiring as one of the simpler tasks.
Matt
Old 25th September 2009, 07:51 AM
I think I'm convinced. I'll spend a day with the loom cutting out all the crap. I fully marked up the loom before I stripped it from the car, so it should go OK
Old 25th September 2009, 08:58 AM
gus's Avatar
gus gus is offline
Peter,
Your using the same engine as me. You basically wont loose any wiring from the engine related sensors, unless you are doing away with the Ford engine module that controls the ignition.
The wiring in the engine bay isn't that bad as it is all needed. It is only the internal car circuits you will be able to get rid of.
Mark
Old 1st October 2009, 10:37 PM
I am going to hijack this thread as I am about to locate my original sierra loom.What I am looking for is the mounting of the fuse box on the bulkhead and where the cable enter the engine. Do you run the loom through the transmission tunnel?
Any photos appreciated as I have a weekend of spaghetti to play with I have any hope of getting the engine running by Xmas!
Old 16th October 2009, 02:40 PM
axle's Avatar
axle axle is offline
After a few attempts and looking at giant wiring loom and few panics
I saved myself the headache and used www.premierwiring.co.uk They made a brand new loom for me a new fuse box.
Regards Axle
