![]() Not recommended, there is a lot of strain ot these plates.
If compleatly stuck, the at least put a bracket at the back of the diff to help support it. ![]() David |
![]() I'll have to search harder then. Thanks for the quick replies
![]() I beleive 3ge can supply them ready cut.
If no the look up your local lazer cutting shop. I wouldn't make them myself again, cost more than getting them ready cut. just my opinion David |
![]() Doesn't cost anything if you can scrounge the steel from the cut offs and make them at work
![]() If you can get the steel go for it. Thicker is OK as well, mine are 6mm (cost me a pint
![]() As for the cutting out - if where you work has a plasma cutter then you are laughing. Failing that, I used hole saws in a drill press to start the lightening slots, then joined them up with a jigsaw. Bit of filing and sorted. Sean |
![]() We do indeed have a plasma cutter. Shame we don't have a laser cutter or cnc. The lathe as alot of play in it also which is annoying. Could possibly mill the holes.
![]() The plasma will p**s it. I am assuming you work for a firm that does steel fabrication, in which case you will have better kit that the average DIYer. 5mm plate is nothing to a decent plasma set (40A and above)
If you are any good with the plasma you could do it freehand, or if worried, make a template in MDF (it's only for 2 uses) although you need to work out the size of the plasma tip, then cut parts of the template oversize, and some parts undersize (external is undersize, internal (cutouts etc.) is oversize) Milling would also work for the holes/cutouts. My lathe had a bit of play, new leadscrews and nuts in the topslide and cross slide sorted that out Sean |
