Old 28th September 2009, 09:31 AM
Another vote for either a bottle jack or threadded bar & washers
I find the problem with using a bar in the bush tubes is that if any amount of force is used, the bush tube may become out of shape !!
It is quite normal for the welds to pull the material on this type of structure
If It was held rigid in a jig, it'll still spring when it is released.
Old 28th September 2009, 12:28 PM
mark mark is offline
I agree a jack or the threaded bar and washers is a better idea
Saying that it only took me about two minutes to sort mine with a bar before they went to powdercoaters and it didnt damage the bush tubes whatsoever, but i should have added above that the bar was a very good fit in the tubes.
Old 28th September 2009, 12:56 PM
Wasn't dissing your sugestion Mark
I must admit, the good ole bar is normally the first tool I reach for
Unlike my 4ft tyre lever, your bar is probably a better fit in the bush tube & unlikey to deform it
Old 28th September 2009, 06:04 PM
No offence taken Bonzo everyone does things different even though we are all trying to achieve the same thing
thanks
Old 28th September 2009, 06:27 PM
Thanks Mark,
i'll give them a try for my next build..
Andy H
Old 28th September 2009, 09:14 PM
spalders spalders is offline
Default welding lower rear wishbones
Thanks guys - so it seems that everyone (?) who has welded these up has had to apply a little correction of some sort. That is reassuring - how much on average have all of your bones been out? Do we need to change the size of the jig to end up with the right final size? Or is the persuasion the way forward? - I was just concerned about building in errors by bending the tubes. It would be interesting to hear what 3GE do when setting up their wishbones.
Off to make the next bone!
Spalders
Old 28th September 2009, 09:42 PM
onedayTM onedayTM is offline
hi spalders,
I put spraggs of rods in place when tacked in jig and they still moved, all varied from 1mm to 3mm. I think if you try and alter position in jig to take into account distortion when it is pushed back out the bush tubes may not be inline. My bottle jack wasn't small enough to do small ends of wishbones so I just used my trolley jack.
tony
Old 28th September 2009, 01:25 PM
Can i ask which powdercoaters you are using Mark, i got friendly with one in Brenda Road, Seaton. Got some good prices but the finish isn't 100%.
"If in doubt get the bar out". Same happened with mine a few mm, pulled it out again and they where fine..
Old 28th September 2009, 06:00 PM
Ive been using a company called motorcool he reconditions radiators and does powdercoating, its at mandale triangle thornaby on the industrial estate.
Im not not sure if his prices are good or not because i didnt shop around, he did some alloys for me a while ago and they were superb so used him again.
He did all 8 wishbones, rear uprights, rack extensions and a rocker cover for about £80 or £90 cant remember exact price. He did say the more things you take the cheaper it is.
They were done in satin black and the finish is faultless
