![]() If the adapter is placed between the upright and the bearing housing one corner will be unsupported as there are only three holes in it to bolt it down.
I have placed mine as in the link attached but am using different calipers. Hope this helps and, I may be wrong too ! ![]() http://www.flickr.com/photos/3046841...n/photostream/ |
![]() Thanks for the reply. I thought there may be enough play in the CV joints but have made some plates just incase.
Are those the 3GE adapter brackets you are using and also what calipers are those? I don't quite get the adapter brackets because the standard caliper mounting holes look almost level with the hub mouting holes, yet the adapter plates bring everything forward the thickness of the plate (10mm?), can the calipers cope with this offset? Also do you know the average thickness of the bell on a brake disc, the part that clamps between the hub and wheel. Might make some spacers until I can afford discs. Thanks |
![]() 3GE adapters and Audi calipers off a TT,yes they need moving a little but they were free and I had drum hubs so it made sense to adapt them.
I will measure the disc and post on here. This shows it a little better. http://www.flickr.com/photos/30468413@N03/3598378729/ Last edited by flyerncle : 30th September 2009 at 07:03 PM. |
![]() The brakes look great, I've been looking for alternatives because I have read the sierra rear calipers aren't great, Audi/VW rear calipers are usually alloy I've read are those?
Did they take much adapting to fit and did you use standard sierra discs? Sorry for all the questions but I'm intrigued. Have you bolted the hub staright to the upright then like I was worrying about there must be movement in the drive shafts. |
![]() Standard disc,calipers are coated in something like enamel(not by me).
Hub is bolted to upright, but holes for caliper need to be moved in a little to get the spacing betwwen disc and caliper right. Just ask and if I can help thats what it's all about. |
