Old 4th October 2009, 11:09 PM
Originally Posted by londonsean69 View Post
I believe (and i stand to be corrected) that there is a rule governing being able to change the speedo function.
ie. it should not be possible for you to change the diplay of the speedo to anything else.
A few people failed SVA for this on LB. It is remedied by fitting some sort of cover over one of the buttons. I think the Vapor ATV dash was the most commonly used variant
Sean
thanks for the reply does it have to be a permanent cover or can it be a bit of plastic held on with blu tack
Andy
