Old 5th October 2009, 12:15 AM
Sean is correct & the cover needs to appear as if its not going to fall off on the way home from the IVA test
some builders have put a strip of ali over the buttons & bent it back behind the dash panel, then for some strange reason it looks permanent but does seem to fall off.
