Old 15th October 2009, 02:06 PM
chriseyj chriseyj is offline
A small warning, I bought some laser cut diff brackets from ebay to later find that they were not exactly to book spec being 5mm wider on the faces that bolt to chassis. I should of measured but welded them as described in book then found mounting holes were too far apart!
Had to weld up holes and drill again.
