![]() With reference to the engine.
I was going 2l pinto or nothing but after checking out a web site that gave different engine sizes, power, weights etc I am not fussed if I end up with a 2l or 1.8, anything that is straight forward to get me through the IVA. I am watching a 2l pinto powered 1984 sierra estate on Ebay at the moment. http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT It is in Kent which is where I will be when it ends. It will have to be cheap as my priority is chassis plates for the next big purchase, if it goes any higher than £150 I will walk away. The ironic thing is about 9 years ago I was the proud owner of a nice 2l SOHC sierra, it only cost me £300 and lasted me for a year. I would like to try a bike engine conversion once the IVA is out of the way.
Sent from my iPad, from who knows where in the world I was building but I am not now! ![]() Build Pictures Build Thread |
![]() the reason i asked what engine you are planning was to do with you saying you have tacked the TR5 into place, i,m using the 1.8cvh engine & had to cut the TR5 tube out as it fouls the carb/manifold, not sure if it causes a prob with other engines, but as the book was written using a pinto engine then i presume it,ll be fine if you do get the pinto,d sierra,
![]() i would think hard about changing from car engine to bike engine after IVA, lots of things to change, maybe go bike engine from the beginning??? speak to Slimtater & Tilly as they have bike engines in their Roadsters, Slims is already been SVA,d & Tilly,s is a current build, maybe they could give you some advice on bike engined Roadsters. cheers andy |
![]() 17 Oct 09
6th day of the build and Sophie and I are of for a drive! [IMG] ![]() First job was to fit the six diagonals, D1 and 2 are an interesting fit so my tried and tested method of cutting a little over size and fettling for a snug fit worked a treat, also a quick look at some forum members build pictures helped. Moved on to the transmission tunnel next instead of the rear section as you need a few chassis plates for the rear and I won’t be getting them for a while. The TT4/5 hoop was constructed on my welding table. I have only tacked on TT 1’s and 2’s and should get the rest done tomorrow, then a 5 week gap in construction before the big 5 weeks of. I have updated the pictures on photo bucket, it does annoy me that they appear in reverse order, ho hum.
![]() 18 Oct 09
I have had a pretty good Sunday all in all. Got up late then straight into the garage, stopped for a Sunday roast, back in the garage until the start of the GP. I have now completed ¾ of the transmission tunnel just the near side top rails to do (TT7, 9, 10), the cuts on either end of TT11 are compound cuts again, they should have a warning against them, took my time with the hand saw and they turned out OK, if they had been standard angles I think I would have finished the transmission tunnel, no rush, I am not setting a time limit, it will get finished. Pictures are updated here is one of today’s work. [IMG] ![]()
![]() Evening,
Despite being stuck in a 6’ x10’ box that the Sergeants mess call a room, I have made contact with the outside world. The technology in my ‘box’ is quite impressive I think. ![]() I have managed to bid, win and pay for a mk2 escort steering rack which was brand new and in the box for £26.66. ![]() I am getting a little ahead of my self, however. I had this, slightly, and misguided may be, miss conception that Mk2 escort steering racks are rare, so I brought it. I have been following a few Steering Rack (SR) threads and believe if I use standard Sierra track rod ends with my new Mk2 Escort SR and a set of 130mm extensions from Rally designs that that will be a working solution. Or am I way of the mark? ![]() I am looking forward to getting home at the weekend to sit and look at my part build chassis to take my mind off this websters course. The forum is light relief at the end of the day too. Bleating on now I’ll get my coat.
Sent from my iPad, from who knows where in the world I was building but I am not now! ![]() Build Pictures Build Thread Last edited by gingea1pom : 20th October 2009 at 10:33 PM. Reason: Bonk spelling |
![]() Hi Ginge,
sounds like you got a bargain on the rack, as for the extensions i haven,t got the info with me at the mo but i too bought the extensions/tre,s & upper & lower ball joint/drag links etc from rally design & they where spot on & look great, i also bought my rack from them too, but mine was more than 26squid.....£65 ![]() ![]() andy ![]() |
![]() Since my last post I have placed my order for £150 worth of chassis plates, which I will be picking up at the Exeter Kit Car Show.
31 Oct 09 First time in the garage for two weeks and it took me 5 seconds to get back in the groove. What with getting up late and having a kids Halloween party to go to at 4pm, I only got to finish the transmission tunnel. 1 Nov 09 I made a start on the RS’s and after asking a few questions on here decided to just weld up the RS1,2,3 frame and the RS4,5,6,7,7a,8,9 frame square on the welding table and wait for the chassis plates so I can get the fames in the correct position. I don’t think it will hold me up as I won’t get in the garage next weekend and possibly not the weekend after (work load on this course is fantastically unrealistic) and the following weekend is the show and the end of this course. Sorry bleating again
