Old 22nd October 2009, 06:01 PM
davef63 davef63 is offline
Default Scuttle
I,m having same trouble in finding the scuttle height. I was hoping that some had already built one
Dave F
Old 22nd October 2009, 06:53 PM
Land Locked's Avatar
I have a 13 page document by Mark Allanson on fabricating a scuttle.
Regards (The mad Sarf Efriken)
Old 24th October 2009, 08:45 PM
Trophy Blue's Avatar
Trophy Blue Trophy Blue is offline
Funily enough, so do I
Old 24th October 2009, 09:24 PM
I wouldn't mind a copy if you happen to have one
Perhaps I could take a few measurements sometime when it is convenient
Old 24th October 2009, 10:01 PM
Pop over anytime, just ring to make sure I am in, PM me your email address and I will send it over (open to anyone else as well)
Old 25th October 2009, 01:47 AM
Oh dear, I should have mentioned that I would be quite happy to e-mail to anyone that wants a copy. Sorry for that oversite.
Old 25th October 2009, 10:01 AM
Mine might be more up to date
Regards
Mark Allanson
Old 22nd October 2009, 07:04 PM
LeonN LeonN is offline
I would hope that some one will pop outside and measure there's. If your engion and rad are in it canot be that hard to work out a sutable scuttle hight. Shore it canot be to critical. Aslong as you can see over it and the bonet still clears the engion.
Old 22nd October 2009, 09:53 PM
fabbyglass
Make it whatever height you want as long as you can see over it...
I made the fibreglass ones approx 10" if that helps?
Biggest problem is engine clearance as you need a straight run down to the nosecone or the car will look odd.
Old 22nd October 2009, 10:06 PM
So any ideas Mark what you will do for my V6? A power bulge & higher scuttle? Hope to see you at the Exeter show to chat about what you can do. Do you have a damaged nose cone, scuttle or formers i could borrow or buy to get an idea of what heights i need?
Also, when you are not busy send me a pm so i can come order my seats. Ideally like to try them if you have some ready without gel coat.
