![]() Yeah thats defiantly one thing i've really enjoyed doing, not many of my friends know how an engine goes together, atleast now i can say i kind of do
1.8 Silvertop Zetec (ZX6R Carbs + Megajolt) + Type 9 My Build Blog: http://www.haynes.co.uk/forums/showthread.php?t=2736 - Last Update: 31st October 2020 Total Spent so far: Stopped counting ![]() |
![]() all credit to you Tatey, when i need help on my cvh i know where to call
![]() ![]() glad you are enjoying yourself ![]() shorty |
![]() Quote:
![]() Well i decided that i might as well continue stripping down the head today, all thats needed doing was to take the camshaft pulley off, remove the camshaft and take the valves out. I managed to get the camshaft pulley off by making a tool to stop the pulley from rotating and a bit of force from mr breaker bar.
I've taken out the little plate which stops the camshaft from coming out, but now I'm at a loss as to how to remove the camshaft oil seal. I don't want to destroy anything when trying to remove it in order to get the camshaft out. So does anyone have an idea as to how to remove it? Cheers Simon
![]() Personally, I normally prise oil seals out with a large flat bladed screwdriver ( Gently !! )
It'll FUBAR the seal but should not be a problem as a new seal will come with the headgasket set, in any event, should be replaced as a matter of course ![]() If you don't feel that confident !!, gently tap the camshaft forward a little & the oil seal should come out with it . The CVH cam can be a little bit of a devil to get out once the cam is clear of the bearing journals. Just be patient, keep the cam level & square to ensure it will pass through the next set of journals without snagging, ( Probaly need to rotate the cam a little too ) . ![]() One last thing, never tap or hit the cam with anything solid, use a copper or plastic mallett. If you don't have one, a small piece of hardwood used as a drift will do no damage ![]()
![]() Cheers for the tips bonzo. I managed to get it out using a flat headed screwdriver and the camshaft came out with no issues, its now stored in a carboard box with my crankshaft and pistons. The only jobs i've got to do now are:
Remove the crankshaft pulley so i can remove the oil seal Remove the valves (im planning on buying a g-clamp and modifying it to be used as a valve removal tool) Then once all of that is done i can start cleaning up all of the parts and then wait until i have the funds to buy the following parts: Piston rings Headgasket set Big end bearings (i dont think ill be buying main bearings at the moment as flyerncle said they looked fine, where as the big end bearings are through to the copper) Get the head skimmed Paint the block Oil filter Spark plugs Thermostat Im just trying to find the best price for the big end bearings now, any ideas? I've tried ebay but there dont seem to be many, enginestuff.co.uk seems to be the cheaspest, but i recon i might be able to find a better price.
![]() Best advice is take crank with bearings to engine specialist like Engine services at Dunston (john) and get him to measure it and they can supply the bearings etc,it may be a good bet at this time to overhaul it completely even though it may cost a fair bit its good policy at this stage,last time I asked him all the bits and pieces were about £200.
As Bonzo says its not worth messing about with oil seals as they come in the head set and dont forget the valve seals. |
