Old 28th October 2009, 11:20 AM
geeman's Avatar
geeman geeman is offline
Originally Posted by Chris Gibbs View Post
I usually use these from Westfield world, simple and easy to understand.
Chris
Ahh, i had seen that westfield one before, but i was using mozilla firefox and the text on the pic was coming up as hashes.. but i used internet explorer this time and it works...
Originally Posted by Coozer View Post
I hung the wiring harness on the garage wall laid out as in the car, then starting at the fuse box identified each circuit and removed them. Check, check - cut!
Having it bundled up in separate pieces is no good as you will keep going over and over the same bits.
What I was left with was an overlong basic loom that I could lay on the chassis and route effectively.
I know the wiring diagrams are confusing as they are individual I found it quite easy having it laid out and learned a lot along the way about the circuits and how they work.
once youd undone the loom tape and layed it out, is each circuit seperate coming out of the fuse box, as i guess i could just look at what fuse it is going to in the fuse box and remove that part of the loom...
hmm... that made it sound much easier... off to the garage i go...
my build pics
