Old 31st October 2009, 05:50 PM
dogwood's Avatar
dogwood dogwood is offline
I'm fitting a full screen during my winter rebuild.
I've got a half screen at the moment, Certainly helps to keep the wind and bugs of you.
Old 31st October 2009, 10:07 PM
I'm currently working on two locost/roadster wind screen kits the first comprises of two bits of dented chassis tubing and the cling film from yesterdays lunch. The second is two bits of carbon effect fibre glass and a bag of smashed glass. I'm planning on selling both through fleebay for about £130+delivery. lol
Old 1st November 2009, 10:03 AM
Very helpfull post
Best make sure I steer well away from those when I see them on ebay
On a more serious note & not to put a downer on the whole idea.
Any pre-produced windscreen is going to have to rely on a constant scuttle shape. For example, a scuttle you personally produce.
Even if they are made as a matched pair, problems may still arise !!??
Being as the Roadster chassis will most likely be home built. When it comes to fitting the scuttle you may find that the chassis is a few mm wider or narrower than the book spec.
You may get the scuttle fitted with a bit of tweaking but where will that leave the fitment of the windscreen ?
I think that this is probably the reason as to why no one has jumped in to fill the gap for this particular item.
