Old 1st November 2009, 10:03 PM
Cobra289 Cobra289 is offline
Originally Posted by dogwood View Post
Thanks for the reply Cobra......I think.
Now I am definatly confused, I have enough trouble with English
Anyway the masters I bought were as supplied by MNR. 0.625 and 0.75.
So I am reasonably happy they will be OK for my app.
Just not sure how to attach the balance bar to the brake pedal.
Once I figured that I can worry about how to balance them,
The balance bar has a tube with an outside diameter of 30 mm, now you can make a hole of 30 mm at the center of the hole of 6.5 mm of the Haynes pedal.
You will get a halve hole of gap that is located at the 31 mm as the book mention.
There you weld the tube of 30 mm of the balance bar and probably you will get a good setup.
You need to know that you will have more surface at the cylinders compared to the Sierra cylinder so that means that you will need to have a heavy force at the pedal, or you change the pedal ratio [make it longer]
Regards,
Cobra289
http://www.donostia.demon.nl
'Improvement' means that you recognize previous mistakes!
Old 1st November 2009, 10:13 PM
dogwood's Avatar
dogwood dogwood is offline
Thanks for that one Cobra.
I didn't realise there was a weldable tube with the bar.
I thought it was some sort of bearing.
Not seen one up close, only on the web.
And longer pedals is my plan anyway, because I find the clutch a bit sharp when in traffic. (Big Feet Like Bonzo )
Old 1st November 2009, 10:18 PM
Yes! you get a weldable tube of 30 mm dia, with a balance bar, the balance bar itself has indeed a spherical bearing like the ones of the rod-ends.
Once you have weld [not to much penetration] you need to clean-out the inside of the tube, because the balance bar need to slide inside the tube.
Use a hand hone machine like the ones used for honing of the master cylinders.
Regards,
Cobra289
Old 2nd November 2009, 10:30 AM
davidimurray's Avatar
You don't have to weld the tube in - it can also be pressed in which is what I used to do on Alu pedals
Old 2nd November 2009, 11:06 AM
To do that you need to use two plates instead of the single plate of 5 mm pedal.
Old 2nd November 2009, 01:06 PM
Or just press a tube into another tube. I actually thought you were not supposed to weld the tube as they were case hardened.
Old 2nd November 2009, 05:15 PM
Coozer's Avatar
Coozer Coozer is offline
Check this pic out, balance bar has a bearing in the middle that slides along the brake pedal letting the force be moved across from front to back.
http://www.demon-tweeks.co.uk/produc...&pcode=OBP0040
This one from Rally Design looks like it comes with the tube needed to be welded to the pedal.
http://www.rallydesign.co.uk/product_info.php?cPath=562_580_581&products_id=406 2
Hope that helps.
MNR Vortx Build Diary
www.mymnrvortx.blogspot.com/
