![]() Ok.
But I do think you will have probs with the float height if you run at the wrong angle. If you make the hose too long the carbs try to pop off when idling as it gets sucked in by vacuum also by having a long length of tube you create bad flow at the carb mouth you should aim to only have a couple of mm between the carb and runner Might be a good idea to add some tube to the middle runners so they end up the same length and bare in mind the float height if you cant get it to idle properly Ray ![]() |
