Old 6th November 2009, 07:54 AM
Wink Ebay
If it is of any use to you. 7/16" UNF nuts,bolts, taps & dies are readilly available on ebay
WE have a similar problem in the UK with the metric fine stuff. Hard to find & expensive when you do.
No real reason as to why you can't use M12 metric fine instead though.
Old 6th November 2009, 09:00 AM
I think I paid £7.99 for a set of 3 7/16UNF dies (taper, second, bottom)
Obviously not the worlds highest quality taps, but for the 4 holes I needed to tap, they were fine.
Same goes for the nuts, I got them off EGay, t'was about £1.99 for 10, in Grade 8.8
Sean
