I did a lot of work on bikes for years (old man had a hire fleet and breakers) but I was only about 10 or 11 ![]() Everything else is self taught, welding, lathe work etc. What is the lathework, let me see
The little lathe in the pictures met an untimely end, I now have a Myford ML7 (much better, all gears and belts, no silly electronics) With a lathe and a mill you will be able to fabricate a lot of stuff youself, although I don't really think I have had call for a mill until today (brake caliper brackets - not necessary in the book spec) I have the attachments to use the myford for milling, so will give that a bash soon If you have a flypress/brake press you are laughing, because otherwise the suspension brackets need to made by brute force (hammer) or bought in
Sean |
