Old 21st November 2009, 08:30 AM
Has any body seen series on discovery about 'mega factories' I remember the Catepillar plant where they cast the chassis in solid steel 24 inches plus thick in 4-6 bits then MIG the whole thing together with 9-10 inch weld preps bet that fella's not using 0.6 wire
He wouldn't be using .6mm wire..........But then, he ain't welding 1.6mm tube is he !!??
Honestly Tallon you can be a complet knob at times
