Old 23rd November 2009, 02:39 PM
Originally Posted by Enoch View Post
It has to be possible to use the wheels on the hubs cos Ford did it
The wheels fit the hub. What they don't clear is the haynes roadster suspension for the double wishbones. 14" steel wheels fit it, but the 14" alloys don't clear the lower wishbone mounting point on the fabricated upright. The spacer would need to be at least 50mm thick to clear the upright/wishbone.
Bear in mind if you just throw on some big wheel spacers you might need to make new arches to cover the extra 4 inches of track.
