Old 29th November 2009, 06:30 PM
davidimurray's Avatar
Default Making an Alu fuel tank
Out of interest - has anyone tried using this stuff -
http://www.durafix.co.uk/
I've seen it demonstrated at a few trade shows and it seems far to easy to to use! Never really paid much attention to it before as I rarely deal with steel but with the prospect of needing a fuel tank they could be quite useful if they actually work!
Old 29th November 2009, 06:43 PM
to be quite honest only a mad man would use that stuff on a fuel tank. i can see issues with the metals expanding at different rates and cracks forming.
MK-Engineering will do you a proper ali welded tank for £80. why take the risk?
Old 29th November 2009, 06:52 PM
I too have seen it a various trade shows David & like you, did not take too good a look, just thought to myself ........" Yet another wonder product "
Being the eternal pessimist that I am. My gut instinct tells me that a weld made at such a low temp will not be suitable for a potential high stess app
If you have a decent heat source availalable, I would stick to the more traditional filler rod & flux route.
I would love to be proved wrong........... Like I said......I have seen the product but never used it
Old 29th November 2009, 06:59 PM
Ash, is that their going rate, or did you manage mates rates because of the magazine article?
Sean
Old 29th November 2009, 07:57 PM
I e-mailed martin this week and was quoted £125 delivered for an injection tank.
Adrian
Old 29th November 2009, 11:44 PM
i wasnt aware that i was getting mates rates. i certainly didnt ask for mates rates.
Old 29th November 2009, 11:52 PM
I wasn't inferring that you did, just wondered if he might have done a better price because of the mag??
Maybe you should have, it might have been £50
Sean
Old 30th November 2009, 08:19 PM
Well I do like to throw a few wild ones out in the mix. These aluminium brazing products seem very interesting. Doing a bit of research - it seems they have been used quite succesfully to build intake manifolds - quite impressive really when you consider the weight hung on them. Looking round a bit further, over on the mig welding forums, there is an example there of using it to fix a pipe into a plate that is subject to 28 inches of vacuum!
Having spent a bit of time making boilers that were silver soldered together, this seems like quite a similar process to me - but made to suit aluminium.
