Old 7th December 2009, 04:53 PM
gingea1pom's Avatar
Originally Posted by 3GE Components View Post
Shopping trolley castors are what you need, they have a huge rating, not that i'd condone pinching a shopping trolley mind.........
Kind regards
John
Cheers John,
I know where there is a stream that could do with a shopping trolley removing from it. Doing my public service and all that.
Build Pictures
Old 7th December 2009, 04:57 PM
gingea1pom's Avatar
i feel like i was ripped off now
Andy,
I think the amount of stuff we got for our £150 is fantastic. There are people selling 1.8 CVH engines on the bay for £500!
Cheers Ginge
Build Pictures
Old 7th December 2009, 05:04 PM
Originally Posted by adrianreeve View Post
Still reckon I win for bargain sierra doner - paid £50 for it, drove it home, then found £15 in change in the glove compartment!
Adrian
My first donor was free + it had 3/4 of a tank of fuel
On the downside...............I only found £1.15p in loose change
Old 7th December 2009, 09:31 PM
mark mark is offline
That looks the same as my sierra did, same colour/engine/age
Mine ran sweet as a nut so felt guilty for the first 5mins of ripping it to pieces systematically ripped to bits of course
If you are using the loom make a good job of labelling it and storing it for when you need it. I spent a full day carefully removing the whole thing in one piece and very neatly labelling it.
I have just recently stripped the loom down and got it in the roadster at the weekend, the labels really helped make sense of it quickly
Old 7th December 2009, 11:01 PM
davidimurray's Avatar
Looking good Ginge - don't forgot to cash the tax in if there is any left - got £50 back on mine
Old 8th December 2009, 07:02 AM
mopple mopple is offline
Hi Ginge, was looking at your roll bar and suspension mount assembly and had a thought. For those nuts there and also for lower harness mounts would be very comfortable to use special weld nuts. They just need a bit larger hole but are self centering and easy to fixate. Here's a linkey with drawing and dimensional table http://www.deepri.com/din_specificat...Weld-Nuts.html. I design conveyors every day and we use them a lot. Don't know how available those are over you, but should be.
Old 8th December 2009, 11:41 AM
good find that is mopple. wish i had those when i did my car.
Old 8th December 2009, 12:26 PM
Cool Weld nuts
I used weld nuts on mine .......... Mind you, only because I had them on my shelf
They are quite usefull though, less likely to pull when being welded & keep nice n square
Old 8th December 2009, 05:13 PM
gingea1pom's Avatar
08 Dec 09
I am not quite sure what I did today but it defiantly wasn’t work on the roadster and the strip light in the garage blew!
09 Dec 09
I finished of the modified rear end and shaped the bar that the upper seat belt inserts go into, which is what the following picture is showing, also it shows my thoughts for the roll bar stays.
[IMG][/IMG]
I am thinking of running them from roll bar right down to the bottom of the rear end. Your thoughts would be appreciated.
My 6 year old James took the picture and it doesn’t look to bad, I might employ him when it comes to documenting the Sierra strip, as my wife has already said she is not spending a day in the cold garage!
Build Pictures
Old 8th December 2009, 05:31 PM
gus's Avatar
gus gus is offline
Looking good ginge.
I did something very similar with my rollbar, except the rear stays were a bit more inboard than where you are holding them.
Have a look at the pic I put up in a previous post.
http://www.haynes.co.uk/forums/attac...4&d=1258721348
Gus
