Old 16th December 2009, 09:02 PM
Enoch Enoch is offline
Default Cp 10 - Which way up?
Hi folks, I see from the book that CP10 has two holes - one is 25mm from the end, the other is 31 mm from the opposite end. What I can't find in the text is which way up does it fit? It will obviously effect the height that the diff sits up so it must have been designed offset for a reason. Anyone know for sure?
Thanks in advance,
Enoch.
