![]() if its injection it should be returning all the time. just put 12v on the fuel pump. do you know how many bar the fuel pump produces? i would guess the regulator on the fuel rail is either 2.5 or 3 bar
by pass is fine. i capped mine off but not sure if it would cause a problem on a v6. certainly wouldnt stop it starting Last edited by AshG : 20th December 2009 at 07:19 PM. |
![]() I'm using brand new FSE Sytec (Bosch 0580254911) Ford Sierra 2.8i 4X4 Injection Fuel bullet pump with a FSE Sytec Universal Fuel Injection Pump Pre Filter.
http://www.flickr.com/photos/29404787@N03/ http://www.flickr.com/photos/41021922@N03/ http://www.flickr.com/photos/56936222@N04/ http://www.flickr.com/photos/79486076@N06/ Finished my roadster after 5 years! Number 27! |
![]() Are the plugs wet?
Try lifting the air plate a little by hand. TT |
![]() It was brand new plugs, but I will check this, cheers
![]() i think he ment is there fuel on the plugs although i could be wrong.
has it got an auto choke? |
![]() If it's the 2.8 MFi in his pics then it will not have a choke..
TBH... I hate K-Jet. I spent 3 hrs trying to revive my m8's MK2 golf 16V after a 6 month layup!! Does the 2.8 have the cold start valve, that can be rigged to spray a little fuel in if the main injectors are not firing.. Other than that and lifting the air plate to stimulate fuel preasure I don't remember much about the 2.8 MFi set up. ask on www.xrstyle.co.uk/forums TT |
![]() Yes, it does have a cold start valve, how can this be rigged to spray fuel? It sounds like most of my problems are fuel related? That's all the bits I replaced, so have a good few tips to try again on Thursday. Cheers Guys
