Old 4th January 2010, 07:48 PM
Hi David
More or less what I done mate
I got a small piece of 10mm flat bar. cut it to the width that i needed, Rounded the edges with a flap disk.
The end result was a rather nice dolly that I could place inside the round tube when it was partly flattened.
This prevented over flattening & distorton of the tube
I would make you a couple of pieces up but alas....I have no more of the 25mm seamless tube left
Can't remember the length either & cannot get to may chassis to measure it for you.
140-150mm seems to ring a bell though !!??
Old 4th January 2010, 08:29 PM
Originally Posted by Bonzo View Post
Hi David
David.......
Ronnie doesn,t have any 25mm tube left cos he made my headlamp stalks
& the way Ronnie has described how to make them works a treat...... cos they look really smart on MY chassis
Thanks Ronnie, they do look the business
Old 5th January 2010, 12:02 PM
Peter-C Peter-C is offline
Slightly off track but is there a minimum size of tube ? I have 19mm, left over from the rear tub and some 22mm. I don't have any 25mm.
Peter
Old 5th January 2010, 12:27 PM
I wouldnt imagine for one moment it matters what size tube you use to fabricate the headlamp stalks.
Provided It has sufficient strength to do the job & has an IVA friendly radius , whatever you have kicking about should be fine
Personally, I would say that 19mm ERW round tube would prove to be a bit flimsy, the 22mm stuff should be strong enough though
Old 5th January 2010, 12:35 PM
Cheers Ronnie
Old 5th January 2010, 01:58 PM
davidimurray's Avatar
Thanks for the tips guys - will have a play when I get some tube.
If you know the mass of the headlamp, then assume it sees say 4g due to bumps - you can work out the deflection for a given tube size
