Old 9th January 2010, 07:05 PM
Hello,
Saturn can supply the Dampertech Protech dampers but the springs are expensive from Dampertech trade price, i have found another supplier for springs but at the moment they can only supply 175, 250, 300 or 350lbs. Not 200 for the rear - although i find 250lbs much better. I will have some more info on Monday and be able to update the price list.
There is also a lot more Haynes relevant items ready to go on the site. Also please not that Saturn is not yet VAT registered so you don't need to add any VAT onto the prices.
BTW Protech are the dampers to go for, bit more expensive than Gaz but worth the invesment.
Regards.....AndyH
Old 9th January 2010, 08:48 PM
Janne E Janne E is offline
Andy are planing to stock spring at 400,450 or 500lbs.
At the moment I have 350lbs in front but then I did the first SFRO (IVA) hi said it was to soft....
So I need springs at 450lbs
Maybe you can have steeringrack for LHD they have a 2.4 rack at R.D, you donīt must have them in stock but if have at the website....
Cheers Janne
Old 9th January 2010, 09:09 PM
Cheers Janne
I'm not sure what the 1.9"x8" springs go upto Janne but i will find out on Monday. For the rack i will be stocking some but need to order a minimum but they can be mixed so i can certainly order a LHD with the rest.
Think i'll put a 2.4 on my car at the same time.
Old 10th January 2010, 09:24 AM
dogwood's Avatar
dogwood dogwood is offline
I know Rally Design do the heavier springs.
Up to 650 in the 1.9"
Now that's some heavy motor
David.
Old 10th January 2010, 09:40 AM
dogwood's Avatar
Not wanting to hijack, but
Spud, was it you that posted a while ago about fitting 250lb springs to the back? I did a search, but can't find it.
If ya got a link it would help, coz I'm defo going to put on heavier springs to support my Lardy
David.
Old 10th January 2010, 11:46 AM
Hello Dave,
here's the link:
http://www.haynes.co.uk/forums/showt...ded+upgrad es
I'm 16st, and the car does feel much more planted on the rear with the heavier springs on.
AndyH
Old 10th January 2010, 05:06 PM
dogwood's Avatar
Cheers mate..
David.
