![]() I uses a couple of laminate floor planks to make my jigs for the front and rear. Worked pretty well, you do need to jig saw them to fit around the rear suspension chassis area. I also used plenty of m12 nuts and threaded bar.
Used mine to position the front shock mount as well, although once brackets were welded I realised I couldn't get the threaded bar out and the jigs were stuck ![]() |
