Old 15th January 2010, 09:23 PM
Tatey's Avatar
Tatey Tatey is offline
Well it looks like i now know what im spending the rest of my money on . Cheers for the help guys.
Old 15th January 2010, 09:42 PM
degmwilliams degmwilliams is offline
Try using some good proper drill bits, dormer are good with gold tip, use a quailty drill, bosch is the best.
Old 15th January 2010, 10:08 PM
To be honest it does'nt matter what you use to drill the hole with pistol,pillar or hand brace if you hav'nt got the work in a vice it will move where ever it wants, if it moves the hole will come out triangluar. A drill run at a slower speed rather than flat out will let the bit cut instead of burn and a good sharp properly dressed drill bit will also help. Every body knows how to make holes in timber but steel is a different matter it's much harder,funny that.
Old 15th January 2010, 10:19 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Its definately worth getting a pillar drill and a decent set or two of drills
proper tools proper job
half arsed tools half arsed job
get some holesaws as well especially if your going to cut out your own diff brackets wishbone plates etc
made my own bike carb manifold with a pillar drill and holesaw
carefull cause next youll need a grinder to sharpen your drills then a lathe then a mill lol
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 15th January 2010, 10:28 PM
Davey's Avatar
Davey Davey is offline
If you have drill bits then you definitely need a bench grinder to sharpen them on, all you need to do is learn how to sharpen drill bits . I've seen some very highly qualified men in engineering circles who couldn't sharpen a drill to save their lives. I've had to sharpen drills on everything from a 9 inch angle grinder clenched between my knees (not funny when its a 2.5mm drill bit ) to a really good quality pillar grinder with a 9 inch fine wheel, after all the other crap I've used to sharpen drill bits this one was a peach! I have a small 250Watt bench grinder/belt sander combo unit and its good enough for sharpening bits on down to 3mm dia, less than that would need a finer stone.
D.
Old 15th January 2010, 10:32 PM
les g les g is offline
we always use a squirt of Drill/Cut fluid it really does help
cuts quicker/better and the drill bits last a lot longer
cheers les g
ps: it also really helps on a jigsaw or hacksaw blade as well
Old 15th January 2010, 10:37 PM
Tatey's Avatar
When using my hand/pistol drill I had the work piece securely in a vice, I'm too health and safety conscious a the moment, I need to wait a while until I have the funds available to buy the pillar drill as I had less money than I thought. Still plenty to get on with now though, ill just finish cutting all of the chassis plates first.
Although....my university owns a lot of pillars drills.... Time to go ask one of my lecturers if i can put the money im paying the uni to good use .
Old 16th January 2010, 08:54 PM
ACE HIGH ACE HIGH is offline
You need to learn how to sharpen you drill bits,allways buy quality ones.
Also some hand drills have a "bench drill attachment",they work well if you are on a budget.Maybe there are "universall models" that will fit your drill.
And you could do what I did 30 years ago,build your own drill press.Mine has worked perfect all this time,plans will be on the internet for all sorts of types,look at the old Popular Mechanics and Mechanix Illustrated,home built tools were very popular in the 50s/60s when credit was unavailable and if you were short of money you simply built the tool or went without.David
Old 16th January 2010, 08:57 PM
Trefolex cutting compound is a miracle!but you still need to learn how to sharpen your drills!,also dont overheat them,if they start to smoke and turn blue back off and let the drill cool.David
