Old 17th January 2010, 10:17 AM
AndyLockwood AndyLockwood is offline
Default Sierra Cosworth 2WD Front suspension uprights
are Sierra Cosworth 2WD Front suspension uprights suitable for haynes use or is the cosworth geometry differant
Andy
Old 17th January 2010, 11:28 AM
they are a four stud wheel fixing
Andy
Old 17th January 2010, 04:59 PM
be aware that they use a pinch bolt rather than a taper and top nut. So the MAXI ball joint will not fit.
Old 17th January 2010, 07:21 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
that could be a bonus especially if you have acouple of mk5,6,7 escort arms hanging around.drill out the rivets and remodel the lower wishbone to suit
also the way the calipers fit to the upright is different too so youd need some calipers theyre four pots bonus but they are heavy got a pair slung under my lathe as too much hassle to fit to standard uprights
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 17th January 2010, 08:24 PM
Ray
Yeah, if ya can find ezzy ball joint you can use them with a bit of work.
I doubt it's worth spending the money as the 4pots are probably overkill for most applications.
